ksam11
#1 Posted : Thursday, July 12, 2012 6:08:03 PM(UTC)
ksam11
My washer stopped draining/rinsing/and spinning in the Regular and Permanent cycles. However it works fine in the Delicate cycle. Based on the other posts, I have made sure that door-safety switch is working fine.
In these modes, the timer runs making clicking noise, some times little bigger (relay on/off type) noises. But neither it drains nor spins.
If I move it to spin in the Delicates section, it works like a champ. !!
Thanks in advance.
Simon / APP Team
#2 Posted : Friday, July 13, 2012 10:04:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the timer is bad. Also check if you are getting cold water.
The timer Part number: 22001026
Here are the breakdown diagrams and Replacement parts for Maytag LAT9605AAE WASHER-TOP LOADING | AppliancePartsPros.com
Thank you. Post the results.
Simon.
