My washer stopped draining/rinsing/and spinning in the Regular and Permanent cycles. However it works fine in the Delicate cycle. Based on the other posts, I have made sure that door-safety switch is working fine. In these modes, the timer runs making clicking noise, some times little bigger (relay on/off type) noises. But neither it drains nor spins. If I move it to spin in the Delicates section, it works like a champ. !!
Thanks in advance.
Groups: APP Team
Hi. Most likely the timer is bad. Also check if you are getting cold water. The timer Part number: 22001026
