delongbeth
#1 Posted : Wednesday, January 23, 2008 5:27:45 PM(UTC)
delongbeth
Our 5 yr old Kenmore freezer, upright has ice on the floor of the freezer as well as blocking the back drain in the wall. We defrosted it (it is a self defrosting freezer) and reset everything, but it appears ice is forming again. Any ideas? The freezer is freezing ok for the moment
kawfeeman
#2 Posted : Thursday, January 24, 2008 8:19:32 AM(UTC)
kawfeeman
can you take a turkey baster and push water through the cond drain hole ?
delongbeth
#3 Posted : Thursday, January 24, 2008 5:28:59 PM(UTC)
delongbeth
I will try this, what if water does go thru?
#4 Posted : Friday, January 25, 2008 3:09:40 AM(UTC)
I use very hot water with the turkey baster to get the drain working, then I wrap a heavy gauge copper wire around the defrost heater, then down the drain. This should fix your problem.
kawfeeman
#5 Posted : Friday, January 25, 2008 4:36:27 AM(UTC)
kawfeeman
just keep trying to push the water through.. start slow and work your way up the ladder slowly ...
delongbeth
#6 Posted : Friday, January 25, 2008 7:42:25 AM(UTC)
delongbeth
Ok, we tried this and water does go throught the drain. It appears that the defrost heater (is that a copper tubing?) is under the back of the freezer. That being the case, shoudl we wrap the copper wire around the defrost heater and UP throught the drain? We we first discovered the problem, the was a cover on the drain plug. We removed it. Was it supposed to be there?:confused:
#7 Posted : Saturday, January 26, 2008 3:36:45 AM(UTC)
You wrap the wire around the defrost heater located behind the back freezer panel, then down the drain!
delongbeth
#8 Posted : Saturday, January 26, 2008 2:57:17 PM(UTC)
delongbeth
Ok, I see, that would mean I remove the panel to do this. Correct?:confused:
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
Kenmore upright freezer cycle of warming up then chilling below zero. (Refrigerator & Freezer Repair)
by bigcheesehead 9/27/2023 9:05:10 AM(UTC)
Kenmore upright freezer model 253.280528015 keeps tripping ground fault (Refrigerator & Freezer Repair)
by Guest 8/24/2023 11:17:55 AM(UTC)
Frigidaire upright freezer model FFFH17F2QWA (Refrigerator & Freezer Repair)
by Guest 4/6/2023 11:29:17 AM(UTC)
Frigidaire Upright Freezer Misbehaving (Refrigerator & Freezer Repair)
by sun_lover 3/23/2023 12:32:46 PM(UTC)
Green Light at bottom front of Frigidaire upright freezer (Refrigerator & Freezer Repair)
by Guest 9/7/2022 10:43:50 PM(UTC)
Sears cold spot upright freezer Model #2423 (Refrigerator & Freezer Repair)
by Guest 9/1/2021 6:06:27 AM(UTC)
Whirlpool Upright freezer throwing itself into defrost mode (Refrigerator & Freezer Repair)
by Wayne O 7/26/2021 10:25:04 AM(UTC)
Frigidaire upright freezer runs for several hours then shuts off (Refrigerator & Freezer Repair)
by Guest 7/21/2021 11:32:11 AM(UTC)
Frigidaire Upright Freezer (FFH17F7H) showing wrong temperature (Refrigerator & Freezer Repair)
by Guest 7/21/2021 6:21:52 AM(UTC)
Frost/ice on only one upright freezer shelf (Refrigerator & Freezer Repair)
by whitedavidp1 4/28/2021 12:33:57 PM(UTC)
Defrost cycle-Fridgidaire mod FPUH19D7LF1 upright freezer (Dishwasher Repair)
by samv 6/23/2020 1:02:25 PM(UTC)
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 9/30/2019 7:09:57 AM(UTC)
GE 20DADRWH Upright Freezer (Refrigerator & Freezer Repair)
by Robo1027 3/3/2019 3:47:26 PM(UTC)
