Dime-sized Holes, W/ Possible Scorch Marks Around Holes. Suspect Drum-supports/bushings/ Bearings????]
Otherwise, Dryer Seems Ok.
Groups ready for retrieval: Senior Expert, Administrators Joined: 7/19/2007(UTC) Posts: 27,455
The first thing I would do is check the front seal which consists of two parts: the felt glide assembly and the lower basket seal (#20 & #21 on the diagram). - The felt glide assembly Part number: AP2150497
