NBLANKE
#1 Posted : Tuesday, September 15, 2009 6:07:20 AM(UTC)
NBLANKE
Dime-sized Holes, W/ Possible Scorch Marks Around Holes.
Suspect Drum-supports/bushings/ Bearings????]
Otherwise, Dryer Seems Ok.
#2 Posted : Tuesday, September 15, 2009 3:40:13 PM(UTC)
The first thing I would do is check the front seal which consists of two parts: the felt glide assembly and the lower basket seal (#20 & #21 on the diagram).
- The felt glide assembly Part number: AP2150497
- The lower basket seal Part number: AP2143044
Here are the breakdown diagrams and replacement parts for the Frigidaire dryer Model FDE336RES2
