Shut up
#1 Posted : Thursday, July 5, 2012 8:01:23 AM(UTC)
Shut up
I installed the new ice maker I received from this co. It still won't make ice, no water is being dispensed to the maker. The water from door works normally. What else can I do to diagnose the reason for it not working ?
Simon / APP Team
#2 Posted : Thursday, July 5, 2012 10:33:32 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi,David.
First check the water valve by switching around electrical plugs at the valve and pressing the water lever at the dispenser.
If the icemaker fills up - the valve is good.
Next - check the optic controls.
Make sure it's on. Open the freezer door and view the LED status:
Two pulses followed by a one second delay. Could be the flapper door is open or the icemaker is in the harvest mode.
Press in the freezer door switch.
When in the harvest mode, the LED will flash once every second.
No lamp - replace the control.
Press in the flapper door:
Two pulses followed by the a one second delay - the optics are bad.
LED is steady on - the optics are good.
The optics control kit Part number: 4389102
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRG25FKBL02 REFRIGERATOR | AppliancePartsPros.com
Thank you/ Post the result.
Simon.
David (Washer Repair)
by David J Robertson 3/14/2014 8:08:07 AM(UTC)
david (Refrigerator & Freezer Repair)
by glennspace 4/28/2013 7:15:53 AM(UTC)
David (Refrigerator & Freezer Repair)
by depascoe 3/29/2012 8:09:31 AM(UTC)
David (Oven Repair (including Ranges and Cooktops))
by David57 10/26/2011 11:45:50 AM(UTC)
by dcrowles 4/3/2010 6:20:26 PM(UTC)
Lee Davidian (Dryer Repair)
by LeeDavidian 1/31/2010 4:55:09 PM(UTC)
