The oven will preheat with no problem. The problem is that it will not re-ignite to maintain the proper temperature. In order to bake, I have to turn the oven off for a second and then turn back on to the temp. I need to bake at for it to come back to the correct temp. It's also a bit slow when coming up to temp. I did not know if it was a sensor issue or an ignitor issue. I did not want to spend the money on the wrong item!
Thanks, Tim
Hi Tim, Most likely the problem is a bad (weak) bake igniter. - The Bake oven igniter Part number: WB13K21
Thanks. I'll try to find it locally!
