timmy68
#1 Posted : Wednesday, July 4, 2012 4:00:43 PM(UTC)
timmy68
The oven will preheat with no problem. The problem is that it will not re-ignite to maintain the proper temperature. In order to bake, I have to turn the oven off for a second and then turn back on to the temp. I need to bake at for it to come back to the correct temp. It's also a bit slow when coming up to temp. I did not know if it was a sensor issue or an ignitor issue. I did not want to spend the money on the wrong item!
Thanks,
Tim
#2 Posted : Thursday, July 5, 2012 3:29:51 PM(UTC)
Hi Tim,
Most likely the problem is a bad (weak) bake igniter.
- The Bake oven igniter Part number: WB13K21
timmy68
#3 Posted : Thursday, July 5, 2012 5:01:48 PM(UTC)
timmy68
Thanks. I'll try to find it locally!
