Makes ice fine. Motor makes sound. Ice does not release. I have emptied the bin and put a few cubes in but ice is not released when you push the lever:confused: Model ksss48qmb00
everything works it just gets very hot between the two doors where they shut
Originally Posted by: eboer ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Makes ice fine. Motor makes sound. Ice does not release. I have emptied the bin and put a few cubes in but ice is not released when you push the lever:confused: Model ksss48qmb00 Remove the ice bin and check the couplers (#16 & #25 at the diagram). - The ice bin coupling Part number: 2220457
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Remove the ice bin and check the couplers (#16 & #25 at the diagram). - The ice bin coupling Part number: 2220457
Thanks ..Discovered that water must have melted and then frozen during the power outage and so ...maybe it was the coupler taht:) was not turning. Melted it with a hair dryer and all is well.
