Washer not starting. led lights flashing. have used reset procedure many times, but this time not responding. Control panel or circuit board? need correct part #. Thx.
Originally Posted by: smoleroff  Washer not starting. led lights flashing. have used reset procedure many times, but this time not responding. Control panel or circuit board? need correct part #. Thx. needs 10 more characters
I gave up on getting a technician to look at my dishwasher. $90 plus parts and their quote on the parts alone was much higher than I could buy them here.
So I ordered both the panel and circuit board -- you can return any part you do not use. I used both . Call the customer service and they will tell you the parts you need as long as you have the model number
