Rose Michelle
#1 Posted : Friday, June 29, 2012 9:10:56 AM(UTC)
Rose Michelle
Hello~
I hope you can help me get a smile back on my daughters face. Her refrigerator has stopped getting cool and the freezer is cool like the fridge should be..also the icemaker is not making ice cubes. I do not want to have to go out and get her another one..I also read on another web site that it may need freon?? if fridge is not getting cold? can you you help me? look forward to your reply. Also what about the filter for the water? how do you know when to change it..had no date.
thank you in advance
Rose Michelle :confused:
Ok the condenser,compressor and fan are running..cleaned off coils and fan. cleared offf all dust. Does that help any?
Simon / APP Team
#2 Posted : Friday, June 29, 2012 10:31:05 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
You need to give me more info to work with.
Check if: compressor, condenser motor, evaporator motor are running.
Are the condenser coils clean?
Please post the results.
Simon.
Rose Michelle
#3 Posted : Saturday, June 30, 2012 12:49:12 PM(UTC)
Rose Michelle
Originally Posted by: Rose Michelle Go to Quoted Post
Hello~
Ok the condenser,compressor and fan are running..cleaned off coils and fan. cleared offf all dust. Does that help any? how long should I wait to check it again.
#4 Posted : Sunday, July 1, 2012 9:12:36 AM(UTC)
You will need to pull the back off and feel the compressor, if vibrating and hot and condenser coils room temperature, you probably have a bad compressor.
Rose Michelle
#5 Posted : Sunday, July 1, 2012 9:14:13 AM(UTC)
Rose Michelle
Originally Posted by: Simon / APP Team Go to Quoted Post
HI.
Simon.
Ok the condenser,compressor and fan are running..cleaned off coils and fan. cleared offf all dust. Does that help any? how long should I wait to check it again. Now what? My daughter checked the fridge this morning and it is still the same..Fridge is warm and freezer is cool but not freezing anything.
Read more: http://forum.appliancepartspros...p;p=749140#ixzz1zOMSh97t
http://forum.appliancepartspros.com
Rose Michelle
#6 Posted : Sunday, July 1, 2012 9:27:39 AM(UTC)
Rose Michelle
Ok my daughter checked it and she says it is hot and vibrating..and the coils are room temp..so what is the part number for this? How difficult is it to change? Thank you and any help would be appreciated..is there a video or something to watch to make sure we are doing everything proper.
Rose Michelle
#7 Posted : Monday, July 2, 2012 12:28:30 AM(UTC)
All syptoms point to a bad compressor. You might want a pro to look at it to conferm.
Rose Michelle
#8 Posted : Monday, July 2, 2012 8:34:06 AM(UTC)
Rose Michelle
HI.
Simon.
Simon~
I checked the compressor,condensor motor, and evaporator motor are running. we also cleaned off the coils..so can you tell me if we can replace it without bringing a pro in to tell me the same thing? and what part are we needing to get,how much will it cost. I appreciate a response asap..thank you.
Rose Michelle
Simon / APP Team
#9 Posted : Monday, July 2, 2012 10:28:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It's the sealed system problem. You can't fix it without the specialist.
Contact local repair company for the estimate.
Thank you.
Simon.
