My water dispencer is leaking. Although the leak is very slow, I'd like to take care of it. My guess is that it's a bad valve. Can anyone help with the part number I need? Basic information on how to replace would also be greatly appreciated...
Groups: APP Team
Hi. This is the water inlet valve Part number: 2188786
To remove the water line from the old one press on the ring around the line and pull it out. To connect it - just push the line in (make sure it's in all the way). The valve is located at bottom right side at the back. You will need a 1/4" nut driver. Don't forget to turn the water off at the faucet. Thank you. Post the results. Simon.
Originally Posted by: jedifan007  My water dispencer is leaking. Although the leak is very slow, I'd like to take care of it. My guess is that it's a bad valve. Can anyone help with the part number I need? Basic information on how to replace would also be greatly appreciated... Thanks Simon
Groups: APP Team
