jedifan007
#1 Posted : Friday, June 29, 2012 8:06:39 AM(UTC)
jedifan007
My water dispencer is leaking. Although the leak is very slow, I'd like to take care of it. My guess is that it's a bad valve. Can anyone help with the part number I need? Basic information on how to replace would also be greatly appreciated...
Simon / APP Team
#2 Posted : Friday, June 29, 2012 11:37:34 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This is the water inlet valve Part number: 2188786
To remove the water line from the old one press on the ring around the line and pull it out. To connect it - just push the line in (make sure it's in all the way).
The valve is located at bottom right side at the back. You will need a 1/4" nut driver.
Don't forget to turn the water off at the faucet.
Thank you. Post the results.
Simon.
jedifan007
#3 Posted : Saturday, June 30, 2012 10:39:40 AM(UTC)
jedifan007
Thanks Simon
Simon / APP Team
#4 Posted : Monday, July 2, 2012 10:20:53 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
KitchenAid Water Dispenser Leak (Refrigerator & Freezer Repair)
by jvfred 10/27/2008 6:56:41 PM(UTC)
