tspencer
#1 Posted : Tuesday, June 26, 2012 9:35:07 AM(UTC)
tspencer
I have a Maytag side by side MSD2356AE with 2 issues: 1.) The arm will not stop the unit from making ice.
#2.) Every so often the ice maker will not shut off the fill function and runs all over the inside of the freezer with enough water to rain into the basement :eek: . Then it will work fine for a few weeks and then does it again. I replaced the valve unit some time ago thinking this would solve the issue. It did not. Did I get a bad valve or is the issue with the ice maker unit itself? Most of the time it works fine, until the next flood:(. I want to be able to trust it again. Are these two issues related?
#2 Posted : Wednesday, June 27, 2012 2:25:45 AM(UTC)
Replacement parts for MSD2356AE models | AppliancePartsPros.com
[COLOR="Blue"]Did I get a bad valve or is the issue with the ice maker unit itself?[/COLOR]
I doubt you have a bad valve as it would be unusual for a replacement valve to have exactly the same problem as the old one.
I would replace the ice maker.
Check that the bail arm in the parts is the same as yours.
If you click on a part's picture a new page will open with more info about it.
[COLOR="Blue"]
Are these two issues related?[/COLOR]
Could be but I am not sure. Depends which switch the bail arm activates when it is supposed to stop ice production.
