AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Button on Bosch dishwasher control panel popped out
Hi! A button on the control panel has popped out and I can't get it back into place. If I could remove the fascia panel, I think I could pop the button back in. Here's a post which shows a picture of the button--but sadly, although I looked at the Q&As, there are no directions for putting it back--or for removing fascia only. Any ideas? http://forum.appliancepartspros...-front-panel-button.htmlDo I have to remove the entire outer door panel as described here, to get to the fascia? As described here: http://forum.appliancepartspros...-bosch-dishwasher-2.htmlMany thanks, Peggy M
Hi Peggy,
You did good job and found all answers on your questions! :) You do have to remove the fascia panel in order to gain access to buttons.
The delay/ start button popped out of my Bosch SHE45M dishwasher - is there an easy way to fix this? The button itself looks fine and the dishwasher runs normally.
Dishwasher Repair
