peggymckee
#1 Posted : Monday, June 25, 2012 3:11:47 AM(UTC)
peggymckee
Hi!
A button on the control panel has popped out and I can't get it back into place. If I could remove the fascia panel, I think I could pop the button back in. Here's a post which shows a picture of the button--but sadly, although I looked at the Q&As, there are no directions for putting it back--or for removing fascia only. Any ideas?
http://forum.appliancepartspros...-front-panel-button.html
Do I have to remove the entire outer door panel as described here, to get to the fascia? As described here:
http://forum.appliancepartspros...-bosch-dishwasher-2.html
Many thanks, Peggy M
#2 Posted : Monday, June 25, 2012 2:49:17 PM(UTC)
Hi Peggy,
You did good job and found all answers on your questions! :) You do have to remove the fascia panel in order to gain access to buttons.
Steve_G
#3 Posted : Tuesday, September 16, 2014 8:17:39 AM(UTC)
Steve_G
The delay/ start button popped out of my Bosch SHE45M dishwasher - is there an easy way to fix this? The button itself looks fine and the dishwasher runs normally.
