A friend asked me to look into her washer, seems that the water level sensor is not telling the water to stop filling the tub. I disconnected the clear tube going from outside tub to control panel, seems to have a block of hair etc logged in it. It also looks as it the is an oriface or peice of metal stuck in there as well. Is this supposed to be there? Thanks Verm
No, the tube must be totally clear. Clean it out, reattach it and you should be fine.
Thanks sidfink43, appreciate the help, kinda thought so, but decided to seek alittle expert advice. Verm Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) No, the tube must be totally clear. Clean it out, reattach it and you should be fine.
