Hi, my ice maker is not dispensing water. The door is dispensing water. I jumped the T and H and it rotated through system. I than jumped the V and L and no water. Should I jump the N and V? Saw this on a previous thread of yours.
Thanks.
ok, Jumped T and H - ran through cycle but no water Jumped N and M - nothing happened Jumped V and L - nothing happened.
Now what can I do????
You have been a member since:: 9/10/2007(UTC) Posts: 9,586
Go in the back and swap the water valve connectors, then close freezer door and dispense water, the water valve should hum and icemaker should fill up with water. If not, you have either a bad water solenoid or a frozen water line.
