Eddy01
#1 Posted : Wednesday, June 13, 2012 10:34:16 PM(UTC)
Eddy01
The timer will not advance when machine is in operation. I have to turn the dial by hand to make the washer go through the cycles. Do I need to replace the timer? Would be grateful for any advice.
#2 Posted : Thursday, June 14, 2012 2:08:40 PM(UTC)
Sounds like the problem is a bad timer.
- The timer Part number: 134049600
Guest (5)
wash cycle will not advance thru (Washer Repair)
by athomason@bellsouth.net 10/19/2013 10:19:17 AM(UTC)
GE wahser cycle will not advance (Washer Repair)
by Wei Lin 7/5/2013 10:32:56 AM(UTC)
dryer timer/cycle will not advance on auto setting (Dryer Repair)
by treehugger 12/24/2010 8:49:23 AM(UTC)
Kenmore front load wash cycle will not advance (Washer Repair)
by dbednarek 12/5/2009 6:51:29 AM(UTC)
