athomason@bellsouth.net
#1 Posted : Saturday, October 19, 2013 10:19:17 AM(UTC)
my wash cycle will only work on the last wash minutes(6). it works fine on this number but none of the higher wash numbers will advance thru wash cycle
fairbank56
#2 Posted : Saturday, October 19, 2013 10:42:41 AM(UTC)
fairbank56
Groups: Expert
The motor is not working in high speed wash. Last 6 minutes of agitation is in low speed. Remove the cabinet and check the blue wire at the motor connector. Probably burned/broken/corroded. If this is the case, you would need to replace the wire terminal in the connector housing. If the connection is ok, the timer may be defective.
Eric
