metroid16
#1 Posted : Monday, June 11, 2012 7:18:47 PM(UTC)
metroid16
Hello
I have a Maytag Neptune front load washer Model # MAH5500BWW
My washer fills up with water when its not in use .
tried unplugging machine and turning water vales off and it still filled up ??
When the water valve is in the on position it sounds like there is water running ?
Im thinking water intake valve ?
Also i have undone the hoses completely from the valves and waiting to see if tub fills up ?
Any thoughts ? Thank you in advance
#2 Posted : Tuesday, June 12, 2012 6:10:06 AM(UTC)
Replacement parts for Maytag MAH5500BWW WASHER- HORIZONTAL AXIS | AppliancePartsPros.com
[COLOR="DarkRed"]
tried unplugging machine and turning water vales off and it still filled up ??[/COLOR]
I am not sure I understand.
Do you mean that you unplugged the unit and turned off the water faucets at the wall?
If yes then you must have 2 problems.
1. the water valve (Item 30 in Section 4) is leaking. You will need both the model number and serial number.
2. one of your faucets is leaking.
Note: the valves in the unit can sometimes leak if there is low water pressure.
metroid16
#3 Posted : Tuesday, June 12, 2012 10:14:42 AM(UTC)
metroid16
Yes i turned off faucets at wall and unplugged machine.
i spoke with a tech on live chat and recommended this part to replace .
AP4026884 (22003245) Valve, water
i ordered this today and will replace and see if it fixes issue .
Thanks for the help
#4 Posted : Tuesday, June 12, 2012 11:54:57 PM(UTC)
It should fix the filling problem.
I would also check your faucets one of them must be leaking.
suziq1023
#5 Posted : Tuesday, October 22, 2013 4:45:35 AM(UTC)
suziq1023
I have the same issue with my washer did the valve, water fix the problem?
tinker901
#6 Posted : Tuesday, October 29, 2013 4:19:06 PM(UTC)
tinker901
Usually it is one of the cold or hot solenoid valve that is jammed open. They are repairable sometimes, but it is best to change it ( 30$ )
The cause for the defect is most probably a bad water filter, or no filter at all.
BogusSVO
#7 Posted : Sunday, May 31, 2015 7:48:56 AM(UTC)
BogusSVO
Looks Like I have the same issue with the tub filling with water.
I have the same model number, MAH5500BWW
Now to figure out how to crack the serial number so I know what part to get from section 4 part 30
The 83 only /87 and later or the prior to 87
I did look for a date code on the back of the machine
Based of a guess, and the only eighty something number I see in the serial number is 85, those are the 5th and 6th digits in the serial number.
So If my guess is correct I will need the prior to 87 valve set.
Can someone confirm this?
Or do I need to post the serial number for it to be cracked?
