patsn1us
#1 Posted : Monday, June 11, 2012 6:39:28 PM(UTC)
patsn1us
not getting water to dishwasher. All of the lines are are clear. what do i check next:o
patsn1us
#2 Posted : Monday, June 11, 2012 6:41:29 PM(UTC)
patsn1us
i need help
patsn1us
#3 Posted : Monday, June 11, 2012 6:45:38 PM(UTC)
patsn1us
im not getting water to my dishwasher. all of the lines are clear but there is no water to dishwasher
:mad:
#4 Posted : Tuesday, June 12, 2012 1:30:52 AM(UTC)
A model number may help others help you.
Check for 120 volts across the fill valve when it should be filling.
If it is there then you have a valve problem.
It could be the valve is bad or that the screen filter on the input side of the valve is clogged.
If it is the screen clean it, do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
Also could be a problem with the overfill float or switch.
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
