janise noble
#1 Posted : Monday, June 11, 2012 5:27:25 PM(UTC)
janise noble
i have a frigidair cook range that has a problem with the oven
sometimes when i try to light the oven it will light but it will not
heat up. and some times it will work ok.sometimes it will only
let gas escape and doesn't light at all. can you help me please
#2 Posted : Tuesday, June 12, 2012 5:19:01 PM(UTC)
Remove the oven floor and the flame spreader. Check the Bake burner for a burned through holes. If there is nothing wrong, replace the Bake igniter.
- The igniter Part number: 5303935066
