i have a frigidair cook range that has a problem with the oven sometimes when i try to light the oven it will light but it will not heat up. and some times it will work ok.sometimes it will only let gas escape and doesn't light at all. can you help me please
Remove the oven floor and the flame spreader. Check the Bake burner for a burned through holes. If there is nothing wrong, replace the Bake igniter. - The igniter Part number: 5303935066
