frankie5angels
#1 Posted : Sunday, June 10, 2012 7:52:44 AM(UTC)
frankie5angels
Hi, Its an older GE before inverters I think and no lights that flash. Everything works but on spin cycle you can hear the pump working but its not spinning. With front cover open I can see motor is not turning. Does this washer have a fuse for the motor somehwhere or any other ideas for the problem. Thanks
Frank
frankie5angels attached the following image(s):
sidfink43
#2 Posted : Tuesday, June 12, 2012 5:41:31 PM(UTC)
sidfink43
You are correct in that you do not have the model with an inverter and error message light. Since it agitates this should mean the motor is okay.
I would use the wiring diagram that is under the console and meter to see if you are getting power to the motor during the spin cycle. I suspect you are not, which may mean the control unit is the problem.
