lightninskyhop
#1 Posted : Wednesday, June 6, 2012 10:45:58 PM(UTC)
lightninskyhop
I have a GE Spacemaker laundry wsm2780d (built in 03). That never worked right on the auto-dry feature. The high and low heat timed dry always worked.
I replaced the timer unit, and now the dryer and timer only works on fluff (without heat).
If I put the dial on any heated settings, as soon as I press the power button, the circuit breaker trips. I'm wondering if there is a bad thermostat somewhere.
Thanks for any tips or insight.
