AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer on heat setting trips breaker immediately
I have a GE Spacemaker laundry wsm2780d (built in 03). That never worked right on the auto-dry feature. The high and low heat timed dry always worked. I replaced the timer unit, and now the dryer and timer only works on fluff (without heat). If I put the dial on any heated settings, as soon as I press the power button, the circuit breaker trips. I'm wondering if there is a bad thermostat somewhere. Thanks for any tips or insight.
Dryer Repair
