Randy Adams
#1 Posted : Friday, September 11, 2009 8:53:49 AM(UTC)
Randy Adams
Squeaky rear drum bearing needs replaced on Frigidaire all in one model number FEX831CS0. Can anyone give me directions on taking it apart?
sidfink43
#2 Posted : Friday, September 11, 2009 12:40:29 PM(UTC)
sidfink43
You will take off the front access panel, console and front panel. Then take off the top, release the belt from the rear access panel and lift the drum up to release it from the plastic bracket. The drum will then come out the front and you have access to the bearing.
Here is the service manual.
http://frigidaireservicetips.com/pdfs/488_3.pdf
I would order the kit and replace all the parts, plus you get a lubricant in the kit.
Good luck.
Rear bearing replacement - Frigidaire (Washer Repair)
by jhicks 2/21/2010 6:19:34 AM(UTC)
Frigidaire rear bearing replacement (Dryer Repair)
by Irontrader 2/5/2010 11:22:38 AM(UTC)
