Squeaky rear drum bearing needs replaced on Frigidaire all in one model number FEX831CS0. Can anyone give me directions on taking it apart?
You will take off the front access panel, console and front panel. Then take off the top, release the belt from the rear access panel and lift the drum up to release it from the plastic bracket. The drum will then come out the front and you have access to the bearing. Here is the service manual. http://frigidaireservicetips.com/pdfs/488_3.pdfI would order the kit and replace all the parts, plus you get a lubricant in the kit. Good luck.
