jerry rothwell
#1 Posted : Monday, May 28, 2012 6:51:26 AM(UTC)
jerry rothwell
I moved the dryer from one home to another and the heater coil started staying on -red hot on all settings except air dry. how do i fix this
jerry rothwell
#2 Posted : Monday, May 28, 2012 11:36:05 AM(UTC)
jerry rothwell
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Tuesday, May 29, 2012 1:21:15 AM(UTC)
Replacement parts for Frigidaire LEQ642DS0 Frigidaire/dryer | AppliancePartsPros.com
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
