I moved the dryer from one home to another and the heater coil started staying on -red hot on all settings except air dry. how do i fix this
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Here are your parts Replacement parts for Frigidaire LEQ642DS0 Frigidaire/dryer | AppliancePartsPros.comCheck the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. |
THIS FORUM IS DEAD!!!!!!! |
