Leak inside of freezer at bottom starting inside rear. Water pressure on door dispenser very low. Think it may be solenoid. Had one replaced a couple of years ago for the ice maker .I thought drain may be clogged but I cleaned it out and now ice has formed all in the bottom up to the door. HELP!
