jnowicky
#1 Posted : Wednesday, June 3, 2009 5:47:21 AM(UTC)
jnowicky
Side by side #59597990 has a leak at the bottom of the freezer door. Traced it to the water dispenser hose. How can I see exactly where the leak is? Does the front panel around the dispenser pop out? Is the hose clamped anywhere inside the door? Was thinking I could snake the old hose down with a new one attached to the old one from the top opening. Am I on the right track? Any help would be appreciated. I unpluged the water dispenser solenoid to stop any flow. :confused:
#2 Posted : Wednesday, June 3, 2009 12:00:48 PM(UTC)
Possible you have to remove the inner door liner (if it's removable). The model number you posted does not come up. Verify and repost it.
jnowicky
#3 Posted : Wednesday, June 3, 2009 12:16:26 PM(UTC)
jnowicky
106.59597990 is the full number. I found a schematic on a sears product page. From the diagram it looks as if there are screws holding the inner door panel to the door under the gasket. I will look for them tomorrow. My daughter's recently purchased home is wherre the fridge is.
#4 Posted : Wednesday, June 3, 2009 9:42:13 PM(UTC)
Good luck and keep us posted.
