birt420
#1 Posted : Wednesday, May 23, 2012 2:18:03 PM(UTC)
birt420
for some reason my the freezer part of my magic chef refrigerator model # CTB1821ARW keeps frosting over completely to the point that it stops working because of all the ice. what could be causing that?
ApplianceJunk
#2 Posted : Wednesday, May 23, 2012 3:06:49 PM(UTC)
ApplianceJunk
Sounds like the refrigerator is not self defrosting like it should.
Your model refrigerator has four parts to the defrost system.
If your defrost system is not working one of these parts has failed.
1. Defrost heater Part number: 63001387
2. Defrost timer Part number: 63001353
3. Defrost thermostat Part number: 63001388
4. Defrost fuse Part number: 63001052
Simon / APP Team
#3 Posted : Wednesday, May 23, 2012 3:27:00 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is with the defrost system.
Inside the fresh food compartment inside the control panel the is the defrost timer.
Locate the opening about the dime size and using the flat screw driver slowly turn the timer's shaft CW until the fridge stops.
In about 15 min. open the freezer and listen to the slight hissing sound of the defrost heater melting the snow.
If nothing happens open the rear cover and check for continuity the defrost thermostat (it must be ice cold), defrost fuse and the heater.
The defrost timer Part number: 63001353
The defrost thermostat #18, heater#13, fuse#16 on diagram#3.
Here are the breakdown diagrams and Replacement parts for Magic Chef CTB1821ARW REF - TOP MOUNT | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
LG LMX28987ST - Motorized Freezer drawer issues (Refrigerator & Freezer Repair)
by GeriatricGinger 4/21/2024 5:27:29 AM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
Samsung Fridge and freezer incorrect temps (Refrigerator & Freezer Repair)
by Guest 4/3/2024 9:24:02 AM(UTC)
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
Freezer temperature varying (Refrigerator & Freezer Repair)
by Guest 4/2/2024 6:15:22 AM(UTC)
GE Profile Freezer Wildly Varying Temps (Refrigerator & Freezer Repair)
by Guest 3/26/2024 3:54:40 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
Intermittent fridge/freezer (Refrigerator & Freezer Repair)
by Hystiker 2/21/2024 4:01:30 PM(UTC)
