angelocerrone
#1 Posted : Tuesday, May 22, 2012 1:08:21 PM(UTC)
angelocerrone
:( My oven burner flame does not light could you tell me what I need to get:(also the broiler does not work
Simon / APP Team
#2 Posted : Tuesday, May 22, 2012 2:14:59 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First check if there is 120VAC to the bake and broil ignitors.If there is 120v - replace both ignitors.If you don't fill comfortable working with "hot" appliance, unplug it and check ignitors for continuity. No continuity - replace ignitors.
You will need a multimeter to run the test.
If the ignitors are good locate the hi-limit thermostat with one black wire comes from the L1 of the control board and another black one from the connector block. Check the hi-limit for the continuity(take one wire off).
No continuity - replace the hi- limit.
The hi-limit thermostat Part number: 7403P249-60
The oven ignitor Part number: 74007498
Here are the breakdown diagrams and Replacement parts for Maytag MGS5770ADB RANGE- S/C S/I GAS | AppliancePartsPros.com
Position#20 , diagram#1.
Thank you. Post the results.
Simon.
Guest (4)
