jeff schroeder
#1 Posted : Sunday, May 20, 2012 8:11:36 AM(UTC)
jeff schroeder
dishwasher don't drain during a cycle... but when you cancel and restart, it will drain. bad board?
ApplianceJunk
#2 Posted : Sunday, May 20, 2012 8:22:02 AM(UTC)
ApplianceJunk
I would see if there is a tech sheet behind the toe plate at the bottom of the dishwasher. The tech sheet will tell you how to run the diagnostic cycle for testing. Of hand I would have to say it does sound like it could be a problem with the control board, Part number: W10039780
Maytag Neptune mah9700a won't drain ...(locking issue?) (Washer Repair)
by Mr.Petes 8/4/2023 4:55:48 AM(UTC)
won't drain completey (Washer Repair)
by Guest 2/5/2023 11:06:41 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
GE top load won't drain or spin (Washer Repair)
by Guest 2/15/2022 10:42:41 AM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Won't drain automatically but it will drain if set manually to spin cycle (Washer Repair)
by adanpro@gmail.com 6/1/2021 6:47:55 AM(UTC)
Kenmore he 3T won't drain/spin, F2 (Washer Repair)
by corvairdoug 8/20/2020 2:23:35 PM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Won't drain,rinse or spin. (Washer Repair)
by dertikop 3/25/2017 5:46:57 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Maytag won't drain... (Washer Repair)
by HyKlas 2/21/2017 5:34:29 PM(UTC)
