A/c Won;t Come On - Unit Make A Small Clicking Sound When You Try To Turn It On. Could It Be The Fuse?
Sounds like you have a bad motor overload protector.
Originally Posted by: maintainitcos  Sounds like you have a bad motor overload protector. So what does one do about a "bad motor overload protector"?
Originally Posted by: tchristian  A/c Won;t Come On - Unit Make A Small Clicking Sound When You Try To Turn It On. Could It Be The Fuse? The fuse and or the Breaker located in your main panel box may be triped. the noise you hear is a sound from a seperate power source that is 24 volt low voltage. You could have a burnt high voltage wire or a set of burnt contactor points. It is for sure that no power is going to the compressor because the fan outside would or should come on when you set the t stat to cool. Be carefull. you are dealing with 220 volts.:cool:
Lg room air conditioner
(Heating, Ventilation, and Air Conditioning (HVAC))
by Guest
2/15/2022 11:49:19 PM(UTC)
Trouble with air conditioner..!!
by Henry_jew
6/21/2019 3:03:19 AM(UTC)
Samsung Air Conditioner Capacitor Replacement
(Refrigerator & Freezer Repair)
by kewarren6
3/8/2017 5:52:17 PM(UTC)
What size air conditioner should I install on my 3,000-square-foot house?
by kelvinsystem
12/20/2013 8:22:38 PM(UTC)
air conditioner
by pizza
11/6/2013 11:21:18 AM(UTC)
Model # WHIRLPOOL AIR CONDITIONER
by Manonbar
7/23/2013 12:19:57 PM(UTC)
GE air conditioner
by Eddie Brown
8/23/2012 2:28:43 PM(UTC)
Air Conditioner
by danconlan
7/23/2012 10:01:24 AM(UTC)
GE Air Conditioner
by 10690
6/15/2012 2:13:05 PM(UTC)
window air conditioner
by Ruth Ann Williams
5/22/2012 4:11:39 PM(UTC)
Frigidaire window Air conditioner fan bearing Noise
by Rory S Drake
3/23/2012 8:41:55 AM(UTC)
E1 Code On Air Conditioner
by seache
7/29/2011 10:54:17 AM(UTC)
air conditioner
by ajmn05
7/20/2011 3:02:25 AM(UTC)
central air conditioner doesnt blow cold air
by rgjessen
7/19/2011 9:01:57 AM(UTC)
frigidaire air conditioner
by jlmac27
6/17/2011 8:03:38 PM(UTC)
