tchristian
#1 Posted : Wednesday, September 9, 2009 7:07:21 AM(UTC)
tchristian
A/c Won;t Come On - Unit Make A Small Clicking Sound When You Try To Turn It On. Could It Be The Fuse?
maintainitcos
#2 Posted : Friday, September 11, 2009 11:12:04 PM(UTC)
maintainitcos
Sounds like you have a bad motor overload protector.
Deborah2005
#3 Posted : Wednesday, August 11, 2010 4:05:14 PM(UTC)
Deborah2005
So what does one do about a "bad motor overload protector"?
fat pat
#4 Posted : Sunday, August 15, 2010 6:28:12 AM(UTC)
fat pat
The fuse and or the Breaker located in your main panel box may be triped.
the noise you hear is a sound from a seperate power source that is 24 volt low voltage.
You could have a burnt high voltage wire or a set of burnt contactor points.
It is for sure that no power is going to the compressor because the fan outside would or should come on when you set the t stat to cool.
Be carefull. you are dealing with 220 volts.:cool:
Guest (5)
Lg room air conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/15/2022 11:49:19 PM(UTC)
Trouble with air conditioner..!! (Heating, Ventilation, and Air Conditioning (HVAC))
by Henry_jew 6/21/2019 3:03:19 AM(UTC)
Samsung Air Conditioner Capacitor Replacement (Refrigerator & Freezer Repair)
by kewarren6 3/8/2017 5:52:17 PM(UTC)
What size air conditioner should I install on my 3,000-square-foot house? (Heating, Ventilation, and Air Conditioning (HVAC))
by kelvinsystem 12/20/2013 8:22:38 PM(UTC)
by pizza 11/6/2013 11:21:18 AM(UTC)
Model # WHIRLPOOL AIR CONDITIONER (Heating, Ventilation, and Air Conditioning (HVAC))
by Manonbar 7/23/2013 12:19:57 PM(UTC)
GE air conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by Eddie Brown 8/23/2012 2:28:43 PM(UTC)
Air Conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by danconlan 7/23/2012 10:01:24 AM(UTC)
GE Air Conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by 10690 6/15/2012 2:13:05 PM(UTC)
window air conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by Ruth Ann Williams 5/22/2012 4:11:39 PM(UTC)
Frigidaire window Air conditioner fan bearing Noise (Heating, Ventilation, and Air Conditioning (HVAC))
by Rory S Drake 3/23/2012 8:41:55 AM(UTC)
E1 Code On Air Conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by seache 7/29/2011 10:54:17 AM(UTC)
by ajmn05 7/20/2011 3:02:25 AM(UTC)
central air conditioner doesnt blow cold air (Heating, Ventilation, and Air Conditioning (HVAC))
by rgjessen 7/19/2011 9:01:57 AM(UTC)
frigidaire air conditioner (Heating, Ventilation, and Air Conditioning (HVAC))
by jlmac27 6/17/2011 8:03:38 PM(UTC)
