denise57
#1 Posted : Wednesday, May 16, 2012 9:11:20 AM(UTC)
denise57
Washer makes a high pitched noise when agitating or spinning. It has done this occasionally for years, just started doing it continuely today. Washer is level. What part do you think is bad? Washer is 12 years old , is it worth fixing?
#2 Posted : Wednesday, May 16, 2012 5:09:20 PM(UTC)
Tilt the washer back and remove the belt. Check how freely the pump pulley is moving in both directions. Post the results.
Here are the breakdown diagrams and Replacement parts for Maytag PAV3300AWW WASHER-TOP LOADING | AppliancePartsPros.com
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Maytag Performa washer fills, drains, spins, but doesn't agitate (Washer Repair)
by shshimo 3/9/2014 8:25:14 PM(UTC)
Maytag Performa Washer loug banging noise when stopping (Washer Repair)
by johncher 2/9/2013 2:43:39 PM(UTC)
Maytag Performa Washer Smoking (Washer Repair)
by Fixineer 1/31/2013 10:22:01 PM(UTC)
Maytag Performa Washer vibrates and walks (Washer Repair)
by Kurt_washer_2012 12/2/2012 5:54:40 PM(UTC)
Rat-a-tat noise from Maytag Performa washer (Washer Repair)
by Inspector Gadget 1/6/2012 3:12:50 PM(UTC)
I think the pump quite on my maytag performa washer (Washer Repair)
by ChevyCowboy 12/9/2011 5:24:18 PM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
Maytag Performa Washer Will Not Agitate Sounds Like Bad Bearing (Washer Repair)
by plamberty75 1/13/2011 11:26:49 AM(UTC)
Maytag Performa Washer Leaking From Bottom While Filling (Washer Repair)
by mjones61 11/7/2010 11:00:15 AM(UTC)
Maytag Performa washer does not spin (Washer Repair)
by ret2002 8/10/2010 2:05:38 PM(UTC)
Maytag Performa washer timer knob removal? (Washer Repair)
by Albert P 1/20/2010 6:41:45 AM(UTC)
Maytag Performa Washer makes loud noise (Washer Repair)
by gsgray2806 12/31/2009 4:49:46 PM(UTC)
Maytag performa washer (Washer Repair)
by semerm12 10/22/2009 2:50:40 PM(UTC)
by scott_lngly 10/21/2009 6:40:23 AM(UTC)
