gtanse
#1 Posted : 13 years ago
gtanse
The lid switch is working and I have replaced the motor coupling.
When I turned the dial to spin after it filled with water, I smelled something burning.
What could be causing this?
sidfink43
#2 Posted : 13 years ago
sidfink43
You could have a problem with the new coupling, as you may have jammed the transmission, or you may have something jamming the pump.
Check them out.
