gtanse
#1 Posted : Saturday, May 12, 2012 3:59:46 PM(UTC)
gtanse
The lid switch is working and I have replaced the motor coupling.
When I turned the dial to spin after it filled with water, I smelled something burning.
What could be causing this?
sidfink43
#2 Posted : Monday, May 14, 2012 4:52:44 PM(UTC)
sidfink43
You could have a problem with the new coupling, as you may have jammed the transmission, or you may have something jamming the pump.
Check them out.
