James Collins
#1 Posted : Wednesday, May 9, 2012 4:36:59 AM(UTC)
James Collins
My Kenmore Ultra Fabric Care electric dryer is not drying very well. I believe the heating element is going bad. Is this a likely scenario? Do you know the part number for a replacement?
Thank you!
James
#2 Posted : Thursday, May 10, 2012 3:16:37 AM(UTC)
Your model number seems to be missing the first 3 digits.
Kenmore numbers are usually 3 digits a period and the 6 to 8 additional digits.
The heating element is a possibility but low on the list.
If the unit is drying poorly then the most common cause is the vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
kenmore ultra fabric care center (Dryer Repair)
by seamonia48 10/16/2011 3:34:53 PM(UTC)
Kenmore Ultra Fabric Care Dryer (gas) won't spin (Dryer Repair)
by tdmbulk 6/29/2010 1:45:27 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Kenmore Ultra Fabric Care (Washer Repair)
by willing303 7/12/2009 7:50:16 AM(UTC)
Kenmore Ultra Fabric Care Dryer (Dryer Repair)
by anniesmomrocks 12/26/2008 5:21:52 PM(UTC)
