seamonia48
#1 Posted : Sunday, October 16, 2011 3:34:53 PM(UTC)
seamonia48
:) the dryer will spin but it does'nt heat as of today sunday oct. 16,2011
seamonia48
#2 Posted : Sunday, October 16, 2011 3:39:40 PM(UTC)
seamonia48
the dryer will not heat up
#3 Posted : Monday, October 17, 2011 12:41:40 AM(UTC)
Your model number is missing the first 3 digits.
It is these digits which specifies who actually made the unit.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
The motor runs off of half the line (120 volts) while the heater requires the full 240 volts.
If power is OK then check the heating coil and then the thermal cut-off for continuity.
