zekebc
#1 Posted : Sunday, January 20, 2008 8:22:36 PM(UTC)
zekebc
When the water valve opens it fills the water inlet assembly and water begins to flow out of the breather hole at the top of the assembly. The water level and float switch assembly are not filled. It just seems the inlet hose can put in more water than the assembly can let out. Any suggestions?
kawfeeman
#2 Posted : Monday, January 21, 2008 4:47:18 AM(UTC)
kawfeeman
if you turn the d/w on and allow the d/w to fill, while filling, if you just turn d/w to off, does it still continue to fill ?
zekebc
#3 Posted : Monday, January 21, 2008 12:18:34 PM(UTC)
zekebc
If you turn the d/w off the water stops, but as soon as you start fo fill within 5 sec water starts to flow out the breather hole on the water inlet assembly. This continues untill the tub is full and then the fill stops at the right level. The cycle continues as normal untill water is called for again, then the same routine all over.
kawfeeman
#4 Posted : Tuesday, January 22, 2008 5:45:57 AM(UTC)
kawfeeman
change the valve...
Flooded washer (Washer Repair)
by cachaco 2/14/2017 12:14:31 PM(UTC)
Dishwasher flooded kitchen (Dishwasher Repair)
by mbalster27 9/20/2013 4:21:16 PM(UTC)
flooded washer (Washer Repair)
by DenD 7/21/2013 6:12:11 AM(UTC)
Compressor and fans run but hurricane flooded refrigerator does not cool (Refrigerator & Freezer Repair)
by YoshimuraXPO 12/10/2012 1:20:26 PM(UTC)
Final rinse never stopped - flooded basement. (Washer Repair)
by Ted Barry 12/9/2011 5:36:42 AM(UTC)
13yr old Whirlpool quiet partner 980 flooded kitchen...what to look for? (Dishwasher Repair)
by brian450 10/11/2011 11:44:31 AM(UTC)
Flooded Basement (Refrigerator & Freezer Repair)
by jppwrs 9/15/2011 10:40:52 AM(UTC)
How long are heat cycles? flooded dryer (Dryer Repair)
by personalt 9/2/2011 3:18:25 AM(UTC)
Can a refrigerator out of a flooded home be saved? (Refrigerator & Freezer Repair)
by PHRoberts 5/4/2010 9:46:55 PM(UTC)
Clothes washer flooded was room! (Washer Repair)
by littlepeople 4/8/2010 5:12:16 AM(UTC)
water level switch failure and flooded floor (Washer Repair)
by bloodm 4/4/2009 12:19:23 PM(UTC)
Dryer was Flooded in IKE (Dryer Repair)
by bls5544 2/26/2009 12:57:12 PM(UTC)
Flooded basement (Dryer Repair)
by hcsilva 9/14/2008 11:22:27 AM(UTC)
kitchen flooded (Refrigerator & Freezer Repair)
by zatoichi 8/24/2008 7:55:19 AM(UTC)
