jpark121
#1 Posted : Sunday, September 6, 2009 5:05:07 AM(UTC)
jpark121
My dryer works with heat as long as I hold the rotary start switch to the right but stops when I let it spring back. I installed the new switch to no difference. If it seems most likely motor problem and before I attempt to replace motor, could you kindly reflect on my idea that I devise a mechanism that will hold the switch to the right and that I can activate at the beginning of every drying cycle? Will this won't damage the dryer and the timer will stop the machine at the end of the cycle?:)
sidfink43
#2 Posted : Monday, September 7, 2009 6:50:20 AM(UTC)
sidfink43
The push or turn to start switch is built that way for several purposes, among them safety.
I understand your desire to save the cost of a new motor, and it seems like what you propose should work and I have seen machines jerry rigged this way with a toggle switch, but do not do it. It is not a safe way to operate your machine.
