kvgraham
#1 Posted : Sunday, April 29, 2012 12:38:50 PM(UTC)
kvgraham
I turn on my dishwasher and all it does is hum. I cleaned everything out of the strainer. It seems like the motor is not rotating. This is a great dishwasher and I know it's older but I want to save it. Help.
#2 Posted : Monday, April 30, 2012 1:53:53 AM(UTC)
Here is the parts breakdown.
Replacement parts for General Electric GSC720Y01WH Dishwasher | AppliancePartsPros.com
Remove power from the unit.
Remove the sump cover from inside the tub,
Check inn the sump for debris that may be jamming the chopper/impeller.
Be careful as there is often broken glass in the sump.
Unless you find something preventing the motor from rotating it probably needs a new motor/pump.
