Rdewees
#1 Posted : Friday, April 27, 2012 10:40:22 AM(UTC)
Rdewees
Ran service test mode 1 which I assume energizes defrost circuit - defroster works during test but as soon as I leave test mode no more defrost - does this mean the control board is bad - everything else seems to work fine.
Simon / APP Team
#2 Posted : Friday, April 27, 2012 12:16:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What makes you think that there is defrost problem?
Can you provide more info on the symptoms.
Does the evaporator fan run?
Thank you.
Simon.
Rdewees
#3 Posted : Friday, April 27, 2012 2:38:23 PM(UTC)
Rdewees
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
Freezer had ice forming on the lower back wall (about 1/8 inch thick). Melted ice with hair dryer - more ice started forming next day. That's when I started running Service tests: Test #1 showed that Defrost thermostat was closed and heater was on as I could see ice melting. I also ran Service test #3 which operates the evaporator fan and I could hear the fan run - did not actually see it run.
Thank you
Simon / APP Team
#4 Posted : Friday, April 27, 2012 4:24:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the evaporator cover and see what pattern is the build up.
Is it snow packed evenly or it's ice in certain places?
Thank you.
Simon.
Rdewees
#5 Posted : Friday, April 27, 2012 4:57:08 PM(UTC)
Rdewees
Hi.
Thank you.
Simon.
Not sure what the evaporator cover is but looking at the back wall cover that has several openings in it like the grill in a car - if that is the evap cover I would say that its evenly packed snow as opposed to ice in certain places. And again I thank you!
Simon / APP Team
#6 Posted : Monday, April 30, 2012 9:18:06 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely you have a bad control board.It's not hard to replace it. Follow the instructions when reprogramming it.
The control board Part number: 12868513
Here are the breakdown diagrams and Replacement parts for Maytag MFF2558KES REF - BOTTOM MOUNTS | AppliancePartsPros.com
Thank you. Good luck. Post the results.
Simon.
Freezer won't defrost (Refrigerator & Freezer Repair)
by ctomlinson 3/26/2016 3:43:13 PM(UTC)
whirlpool freezer won't defrost (Refrigerator & Freezer Repair)
by JEschCO 6/24/2012 12:12:12 PM(UTC)
Freezer won't defrost on it's own. (Refrigerator & Freezer Repair)
by berhiet 4/26/2012 10:17:22 AM(UTC)
by czhaiku@gmail.com 2/16/2012 6:04:59 AM(UTC)
by mnowlan 2/16/2011 4:43:10 AM(UTC)
by golfersteve 4/29/2010 3:37:46 PM(UTC)
