Rdewees
#1 Posted : 13 years ago
Rdewees
Ran service test mode 1 which I assume energizes defrost circuit - defroster works during test but as soon as I leave test mode no more defrost - does this mean the control board is bad - everything else seems to work fine.
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
What makes you think that there is defrost problem?
Can you provide more info on the symptoms.
Does the evaporator fan run?
Thank you.
Simon.
Rdewees
#3 Posted : 13 years ago
Rdewees
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
Freezer had ice forming on the lower back wall (about 1/8 inch thick). Melted ice with hair dryer - more ice started forming next day. That's when I started running Service tests: Test #1 showed that Defrost thermostat was closed and heater was on as I could see ice melting. I also ran Service test #3 which operates the evaporator fan and I could hear the fan run - did not actually see it run.
Thank you
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Remove the evaporator cover and see what pattern is the build up.
Is it snow packed evenly or it's ice in certain places?
Thank you.
Simon.
Rdewees
#5 Posted : 13 years ago
Rdewees
Hi.
Thank you.
Simon.
Not sure what the evaporator cover is but looking at the back wall cover that has several openings in it like the grill in a car - if that is the evap cover I would say that its evenly packed snow as opposed to ice in certain places. And again I thank you!
Simon / APP Team
#6 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely you have a bad control board.It's not hard to replace it. Follow the instructions when reprogramming it.
The control board Part number: 12868513
Here are the breakdown diagrams and Replacement parts for Maytag MFF2558KES REF - BOTTOM MOUNTS | AppliancePartsPros.com
Thank you. Good luck. Post the results.
Simon.
Freezer won't defrost (Refrigerator & Freezer Repair)
by ctomlinson 9 years ago
whirlpool freezer won't defrost (Refrigerator & Freezer Repair)
by JEschCO 13 years ago
Freezer won't defrost on it's own. (Refrigerator & Freezer Repair)
by berhiet 13 years ago
by czhaiku@gmail.com 13 years ago
by mnowlan 14 years ago
by golfersteve 15 years ago
