dryer starts will run only if start switch is held to right against spring pressure.
Dryer runs motor good dryerheating.Dryer works as designed as long as I tape start switch to right and hold it there.Dryer stops running as soon as spring brings it back to left.
Quote:...Dryer works as designed as long as I tape start switch to right and hold it there.Dryer stops running as soon as spring brings it back to left... The motor start winding has gone bad. Gene.
