hellrung1922
#1 Posted : Friday, September 4, 2009 2:10:03 PM(UTC)
hellrung1922
dryer starts will run only if start switch is held to right against spring pressure.
#2 Posted : Friday, September 4, 2009 3:38:42 PM(UTC)
Sounds like the motor has gone bad.
- The motor Part number: AP2043550
hellrung1922
#3 Posted : Friday, September 4, 2009 4:48:21 PM(UTC)
hellrung1922
Dryer runs motor good dryerheating.Dryer works as designed as long as I tape start switch to right and hold it there.Dryer stops running as soon as spring brings it back to left.
#4 Posted : Saturday, September 5, 2009 2:33:17 PM(UTC)
Quote:
...Dryer works as designed as long as I tape start switch to right and hold it there.Dryer stops running as soon as spring brings it back to left...
The motor start winding has gone bad.
